Enable RMON on a Port or VLAN
  • Enable RMON globally.
Use the following procedure to enable RMON on an interface.
  1. Enable RMON on a VLAN:
    1. In the navigation pane, expand Configuration > VLAN.
    2. Select VLANs.
    3. Select the Advanced tab.
    4. In the row for the VLAN, double-click RmonEnable, and then select enable.
    5. Select Apply.
  2. Enable RMON on a port:
    1. In the Device Physical View, select a port.
    2. In the navigation pane, expand Configuration > Edit > Port.
    3. Select General.
    4. Select the Interface tab.
    5. For RmonEnable, select enable.
    6. Select Apply.
